b16 head torque specs
Old Feb 25, 2006 | 02:33 PM
DJYoshaBYD's Avatar
Default b16 head torque specs
ok.. just got back from luch.. my engine is starting to stumble on startup and there is a liberal amount of oil where the head meets the block by the timing belt... I know I need a new head gasket.. I KNOW!!! lol
but what I dont have are the torque specs for my b16 head.. there is no store around me that carries a book with this motor in it...
does anyone have a book? does anyone know the numbers by heart?
I need:
cam bearing cap torque
Head torque and order of torque (literally out of the book if you can)
I need this info so I can change the head gasket before it REALLY goes....
Old Feb 25, 2006 | 02:43 PM
Nail I3unny's Avatar
Default RE: b16 head torque specs
look for an 99-00 si chilton.
Old Feb 25, 2006 | 02:44 PM
DJYoshaBYD's Avatar
I cant find any of those either,,, I dont have time to wait, because I have a 60 mile commute everyday... do you happen to have one?
Old Feb 25, 2006 | 03:18 PM
DJYoshaBYD's Avatar
I found em
thanks
Head bolt = 63 ft/lb +/-2
Cam holders = 22 ft/lb +/-2 and the outside 6mm bolts are 8 ft/lb.
Remember to torque it in 3 steps and follow the seguence, it's usually
inside out. If you're using an extension, add a couple more
pounds to it to compensate for torque loss.
caveman1990
Nov 16, 2011 05:15 AM
noclubclub
Jan 25, 2010 03:34 PM
tombakers
Feb 28, 2008 11:43 PM
joey
Jun 10, 2006 04:08 PM
slvcivic00
Jan 26, 2005 07:40 PM
