d15b or z6
RE: d15b or z6
yeah i was leaning more toward the d15b, but that motor is like $500 but i can get the d16 for like 2 or 300 from my friend. i like the thought of the full jdm motor though, so i dont know. but keep the feedback coming. if u have any kind of info on the motors, feel free to let loose.
RE: d15b or z6
not really any advantage. the d15B has a better rod to stroke ratio, which will allow it to rev a bit higher easier (lower piston speeds=less broken parts). custom pistons are hard to find for a d15b, because it usess the longer d16 rods so the piston is special design
so if you are going to build it internally then it would be easier to go with a z6 because you can get cheaper off the shelf internal parts for it
