B16 timing belt
Old Nov 29, 2005 | 12:49 AM
nightrider46's Avatar
Default B16 timing belt
If the timing is a lil bit off target or if it skiped a lil, will it still throw out some spark ?
Old Nov 29, 2005 | 10:32 PM
riceburner700's Avatar
Default RE: B16 timing belt
yeah your timing is either gonna become advanced or retarded, should notice either more acceleration(retarded) or more top end(advanced)?
Old Nov 29, 2005 | 10:35 PM
sbowers's Avatar
take it off and try try again
Old Nov 30, 2005 | 12:04 AM
sacicons's Avatar
if its off a tooth, it will barely idle, and have no power. i have explained how to do the cam timing a few times here, but its kind of long, so do a quick search and you should find it. it will be in a pretty old post, its been awhile.
Old Nov 30, 2005 | 01:42 AM
So if it's off a tooth you will still have spark running to the spark plugs ? cuz i could crank my car but it wont turn over
Old Nov 30, 2005 | 11:40 AM
Kappa22's Avatar
If you're not getting spark, check your dizzy.
Old Nov 30, 2005 | 02:03 PM
wat's a dizzy?
Old Nov 30, 2005 | 03:07 PM
Kappa22's Avatar
Sorry... your distributor.
Old Nov 30, 2005 | 04:09 PM
It is a Brand new distributor
Old Nov 30, 2005 | 06:01 PM
sacicons's Avatar
if your timing is off, it will still spark, it will just do it at all the wrong times, so if its not sparking at all, check your connections and maybe, just maybe, your ECU went out.
