B18 Type-R in my 92 si
Old Oct 22, 2006 | 08:09 AM
Jordon 92's Avatar
Default B18 Type-R in my 92 si
I plan on doing this swap next year when the weather gets better. But I was wondering if any of you could enlighten me on what I could actually do to the motor to put out more power. Is there actually any bolt on's that are better than whats on it now? And I know I can do ignition, suspension, clutch and fuel pump. Just trying to get some more ideas so I can make up a budget this winter.
Old Oct 22, 2006 | 09:39 AM
drbyers's Avatar
Default RE: B18 Type-R in my 92 si
you could cam it, supercharge it, turbo it, chip it or just leave it alone.
you could also add aftermarket intakes, headers and exhausts.
i'd just leave it alone. it's going to have roughly 200 horsepower in its stock form. that's way more than what your 92 si's OEM is pushin...
Old Oct 22, 2006 | 10:46 AM
Jordon 92's Avatar
Well the civic now has a GReddy turbo kit on it. So Its proabably close to being the same. But if I were to turbo or w/e I would have to put in low compression pistons. I think 11:1 is much too high to boost. And I dont exactly have a tuner nearby, probably pittsburg would be the closest and thats a 2 1/2 hour drive from here.
Old Oct 22, 2006 | 10:54 AM
Remmy's Avatar
If you go and do that I wouldnt go over 9:1 compression.
Old Oct 22, 2006 | 03:29 PM
t34me's Avatar
^true, and with that, it kinda defeats the purpose the the C5 motor. If you do get it, keep it NA
Old Oct 22, 2006 | 04:18 PM
Jordon 92's Avatar
Yeah I wanna keep it NA otherwise I would save myself about $1000 and get the B18C1
Old Oct 22, 2006 | 04:36 PM
ef4life's Avatar
civic type r cams have a more aggressive profile, look into a thinner head gasket for more compression. omni power flat face valves, ctr crank pulley. good tune with hondata on the dyno.
not really any bolt ons that will give you significant hp, until you go into the internals.
Old Oct 28, 2006 | 12:09 AM
b5spoolin's Avatar
ORIGINAL: ef4life
Agreed. I would also recommend upgrading the clutch/ flywheel while it's out(easier that way).
Ghetto2315
Jul 13, 2008 03:18 PM
TungUpInYaThong
Oct 26, 2007 04:10 PM
Fiirkan
Sep 21, 2007 04:32 PM
krzemienr
Dec 7, 2006 01:30 PM
blkcivicman05
Apr 29, 2005 10:37 PM
