Bad knocking! NEED D16Z6 Help!!!
Old Mar 11, 2007 | 11:44 AM
speedemon's Avatar
Default Bad knocking! NEED D16Z6 Help!!!
My z6 is knocking really bad. Reving high due to a bad TPS.Block from junk yard, rebuilt head, Apexi AFC, I followed the manual to reinstall this damn thing and im out of money and losing my patience. I need help!
Old Mar 11, 2007 | 01:13 PM
Pete's Avatar
Default RE: Bad knocking! NEED D16Z6 Help!!!
Why do you have the Apexi unit? Get rid of it and leave your ECU stock. Get a new TPS sensor.
Old Mar 11, 2007 | 01:50 PM
speedemon's Avatar
i have the afc just for added tunability. i know it was probably a waste but i like it. anways the timing seems to be right. i followed the repair manual to a T on how to time it. the shop that rebuilt the head said that they took care of the valve play and said it shouldnt tick at all. but its definitly knocking! i dont know what to do!!!!!!!!!!!
Old Mar 11, 2007 | 04:12 PM
Like Pete said, try running your stock ECU
Old Mar 12, 2007 | 07:55 PM
t34me's Avatar
ORIGINAL: speedemon
What are you going to tune?? Its stock...nothing there. Try sensors first, like they said, TPS, then move into internals.
Old Mar 13, 2007 | 08:53 AM
speedemon's Avatar
Found the problem! bent rod.... so back to work.
Old Mar 13, 2007 | 06:19 PM
HaZe89's Avatar
what kind of pistons does your z6 has?
Old Mar 13, 2007 | 07:07 PM
speedemon's Avatar
all stock internals
Old Mar 13, 2007 | 08:39 PM
HaZe89's Avatar
does your stock internals are low compression pistons???
spevie
Jan 13, 2021 01:48 PM
CloudMage
Jun 4, 2012 07:20 PM
walt79
Feb 15, 2010 12:36 PM
2MARIO2
Jun 14, 2007 04:23 PM
wizzard
Jun 4, 2007 01:32 PM
