block guard
Old Mar 7, 2011 | 08:40 AM
joeunit96's Avatar
Question block guard
what do you guys think, is it worth putting one in? i have heard mixed thoughts on a block guard. do you think it would be safe to run without one? i am building a b18b turbo for about 400whp.
Old Mar 7, 2011 | 08:44 AM
I know nothing about them personally, so I Google'd it. Seemed pretty easy. Maybe you try dis time
http://www.google.com/search?hl=en&b...+it%3F&spell=1
Old Mar 7, 2011 | 05:29 PM
Scott53092's Avatar
Block guards go both ways. I know some people who swear by them, more people I know of are against them though. For 400 whp you might want to consider full sleeves before a block guard as you are starting to get pretty high in the hp numbers for the stock sleeves. A tech at work has a da he built, twin turbo, and he is looking to make 350-400 whp when he is done, and he is block guardless and sleeveless.
Old Mar 7, 2011 | 09:55 PM
209Chris's Avatar
U cant go wrong with a block guard it wont hurt a thing how much boost u plan on runnin and stock pistons??
Old Mar 8, 2011 | 11:15 AM
StifflersMom's Avatar
Cat Fuсker
And how much experience with them do you have? That statement is far fro valid. It CAN hurt your engine. There's such a thing as thermal expansion rate which is different for different metals. The block guard is usually not of the same material as the block and sleeves and expands at a different rate. You can cause many issues there.
Old Mar 8, 2011 | 05:20 PM
Scott53092's Avatar
Cooling is also another aspect of the block guard that is highly debated as well. You are effectively making the motor a closed deck and even though the guards are drilled they are still restricting coolant.
Old Mar 8, 2011 | 10:59 PM
209Chris's Avatar
Last 3 outta 4 motors I built had em never had an issue that same thermal expansion is what moves the cylinders around on hondas blowen head gaskets and such last engine I built went with a dart racing block those r closed deck motors that once again work fine as far as cooling I realize its all 1 type of alloy as opposed to block guards but ive ran these and havent had any issues at all
tombakers
May 4, 2008 05:23 AM
copyguy6188
Mar 19, 2008 07:54 PM
Fiasco
Apr 16, 2007 03:15 PM
4doorturbo
Aug 27, 2006 10:25 PM
smokingemcee
Jan 24, 2006 11:32 PM
