broken bolt help..big pic.
Well..i found a broken bolt today...
its in there pretty deep and i have no way of grabbing it or anything
should I drill and Tap it or is there any other options?
god...well..i drilled and attmpted to use an easy out...but...the drill wont latch on to the easy out...
im letting it soak in liquid wrench...maybe that will soften it up....
otherwise if its not out tommorow..im gunna drill and retap.
i dont think that would be a good idea the the motor.... isnt the block and such aluminum....... ya definatly dont want to crack it or knock the threads out....
ORIGINAL: addiction2bass
