built block turbo b16 (hp limit)
Old Dec 15, 2007 | 08:09 AM
tombakers's Avatar
Default built block turbo b16 (hp limit)
hi, i was wondering what is a safe everyday daily driverhp limit onmy to bebuilt b16a2 on boost!
engine spec:
wiseco forged9:1 pistons 81.5mm
eagle h beam rods
Golden eagle block gaurd
cometic head gasket (standard thickness)
arp main studs
arp head studs
acl race bearings
i was thinkin 350 flywheel power is this too much for a daily driver?
also has anyone any knowledge o f a best procedure to run it in?
Old Dec 15, 2007 | 08:20 AM
PNK SLP's Avatar
Default RE: built block turbo b16 (hp limit)
what kinda boost are u runnin? im runnin 15psi with 470 to the wheels an its my DD....ur set up looks prettty good man id say is goin to be ok as a DD..350 is crazy fast..i know it a hot subject but get it sleeved if ur runin over 12psi for a DD. thats alot stress an pressure on everthin.
i have apr head studs an there workin great.
what injectors are u lookin to run? an turbo?
Old Dec 15, 2007 | 08:25 AM
MY99SI's Avatar
ORIGINAL: PNK SLP
im curious on the timing map, b/c thats ALOT of power with a small amount of boost.
Old Dec 15, 2007 | 08:33 AM
tombakers's Avatar
you got some crazy figures on your ride, i have been boosting with 440 cc injectors uprated pump and crome remap on a t04e turbo.
can stock sleeves really only take 12psi or does it dependon turbo size
Old Dec 15, 2007 | 01:56 PM
Lost's Avatar
ORIGINAL: PNK SLP
Sounds like BS to me. 15psi and 470whp wow! Lets see the sheet...
Old Dec 15, 2007 | 02:53 PM
PNK SLP's Avatar
ook man yeah i just came on this site to b.s my number to act cool, ill post my dyno sheet in a month or two when im hittin over 500 Wheel h.p. have u seen my mod list??? oh an how about u just stop talkin an stop actin like u know everythin.
Old Dec 15, 2007 | 02:54 PM
PNK SLP's Avatar
oh an tombakers i would be ruunin at least 550 or 800cc injectors if ur wantin to get 350whp
Old Dec 15, 2007 | 03:05 PM
Lost's Avatar
I dont wanna see a dyno sheet next year when your making 900whp on 17 psi. I wanna see 470whp on 15 psi. Where are your "mods" listed?
Old Dec 15, 2007 | 03:09 PM
PNK SLP's Avatar
is around the forums somewere id post it here but i dont wanna jack this dudes post
Old Dec 15, 2007 | 08:39 PM
ScoobyAddict14's Avatar
formerly aryiman98civic
ORIGINAL: tombakers
it honestly depends on how good of a tune you have man. you sound like you have a good setup for engine wise. you would be safe to be running 15 psi if you have a good tune. id go to someone who is reputuable in your town or in the honda tuning world.
