CEL
Old Jul 1, 2008 | 05:26 PM
civic_eg_ls's Avatar
Default CEL
Hey guys well i just bought a 92 civic with an Integra Ls motor. Does anybody know why check engine light come on or what can i do to fix it?
Old Jul 1, 2008 | 06:11 PM
Default RE: CEL
The check engine light comes on when one of the various sensors in the car detects a problem. You can drive to auto zone or advance auto parts, or whatever auto parts store is in your area, and they will check the code, which will tell you what is wrong with the car.
My first guess would be that something was not done properly when the swap was done. Does the car have the computer for the Integra LS engine in it?
Get the code scanned first, look up the code, and it will tell you what is causing the light to come on.
Old Jul 1, 2008 | 06:43 PM
Default RE: CEL
Yes it does have the Integra Ls computer. Well ima go to autozone and check the code. Thanks
Old Jul 1, 2008 | 08:40 PM
Default RE: CEL
ORIGINAL: civic_eg_ls
If the ECU is OBDI, then AutoZone probably won't be able to pull the code(s) with a scan tool. Try the jumper wire method described in the CEL link in my signature.
Old Jul 1, 2008 | 10:28 PM
Default RE: CEL
Thanks
Old Jul 1, 2008 | 10:41 PM
Default RE: CEL
The engine is a 98 Ls so i guess its a OBD2 right??
Old Jul 1, 2008 | 10:50 PM
Default RE: CEL
The stock 98 engine would use OBDII. Your engine would be the same unless it was converted to OBDI during the swap.
Old Jul 1, 2008 | 11:08 PM
Default RE: CEL
Ok thanks
Nelly
Apr 10, 2007 11:31 PM
turbo y7
Jun 4, 2005 03:06 PM
hxcivicboy
Jun 4, 2005 12:12 AM
b16Ek4
May 25, 2005 08:48 AM
215civic
Apr 20, 2005 10:27 PM
