CEL after cylinder head replacement
Old May 29, 2013 | 06:57 PM
always workin's Avatar
Default CEL after cylinder head replacement
Ok, here is the story. I replaced the cylinder head because of a blown head gasket. In addition, I replaced the following:
Reservoir cap
Radiator cap
thermostat
new coolant
Oil and filter
Adjust the valves
I ran the car for nearly 2 hours filling and burping the air from the system. The temp gauge never went over half. The check engine light is on and the car now runs rough. What are your thoughts? Im guessing I need to run the code. Can an auto parts house runt the code on this or do I need to go to a mechanic?
Old Jun 19, 2013 | 06:08 PM
go-part's Avatar
Former Sponsor
Get the Cel code first, it should lead you directly to what is causing your problem.
WellFedHobo
Feb 25, 2010 03:56 PM
jonsaidthat
Oct 30, 2008 05:04 AM
GirlwithanSIattitude
Jan 6, 2008 06:18 PM
sway2003
Dec 27, 2006 07:33 PM
lvo civic
Mar 16, 2006 12:43 AM
