Coolant drain bolts
Old Aug 13, 2007 | 04:42 PM
zhmendak's Avatar
Default Coolant drain bolts
Hey guys.
I am replacing my radiator on my civic dx and I want to drain coolant out of the block too, but I cant locate the coolant drain plugs on the block. It's D15B7. I want to know if this block has them or not.
Old Aug 13, 2007 | 04:51 PM
Default RE: Coolant drain bolts
probably not...... just hook it all up and keep the drain plug open on the radiator with a garden hose running into the top of the radiator to keep it full and let the motors thermostat cycle thru a few times or till water from the drain is clear... then just drain again and pour in some PURE radiator fluid so the mix is alittle more pure so it will mix with the water in the heater core and block to mix it out preaty close to proper mixture....
soundquest
Jul 27, 2021 08:23 AM
paak
14
Nov 19, 2011 02:24 PM
ELLAS1945
Jul 12, 2007 11:13 AM
RLaP
Nov 17, 2005 12:32 AM
Toppers
Oct 1, 2005 09:22 AM
