Crank Pulley Debate
Old Apr 21, 2007 | 03:26 PM
Big T's Avatar
Default Crank Pulley Debate
I know there is debate on whether to change your crank pully.I knowan underdivencrank pully isn't good, but what about just a size difference?What are the advantages and disavantages and should I get one?
Old Apr 21, 2007 | 03:55 PM
riceburner700's Avatar
Default RE: Crank Pulley Debate
dont even waste your money, i just finaly got mine off because the bolt stuck in tehre and NOTHING would take it off. I didnt even see a difference in power
Old Apr 21, 2007 | 05:37 PM
Fiasco's Avatar
you can get power gains in more logical ways
Old Apr 21, 2007 | 06:18 PM
Lost's Avatar
Ya, Im not sure what all the hype is about these things, I guess its cause they look nice.
Old Apr 21, 2007 | 10:24 PM
mxs's Avatar
mxs
ORIGINAL: Big T
I know an underdiven crank pully isn't good, but what about just a size difference?
but the size change is what makes it an underdrive pulley....
they also weigh a lot less
Old Apr 22, 2007 | 09:58 AM
StifflersMom's Avatar
Cat Fuсker
and are fine to use if you DO NOT have a harmonic balancer built into your original.
Old Apr 22, 2007 | 10:59 AM
antrmo's Avatar
i felt some power gains in mine. not lots but a little. and ya is does look nice, the difference in wieght when i held them both was huge.
Old Apr 22, 2007 | 02:00 PM
shopmanual's Avatar
If you really want to get rid of your stock pulley just put on a lighter billet aluminum one that's the same size. That will reduce the rotational weight a little and give you a small power gain, but there are better things to invest you money in.
Old Apr 23, 2007 | 05:52 AM
Live_4it's Avatar
ORIGINAL: Roto
I think thats the main thing that I heard about using all 3 pulleys. But I also read I believe in a performance book that honda engines are built in a way that it wont effect your engine's balancer and ruining it in a short span of time.
Old Apr 23, 2007 | 05:54 AM
Live_4it's Avatar
ORIGINAL: riceburner700
Did you only have one pulley in? I heard it's useless unless you get all three.
Karrde
12
Jan 24, 2009 05:09 AM
02CivicSISLVR
Sep 12, 2006 11:43 AM
ray90813
Jan 10, 2006 05:44 PM
skidbump
May 15, 2005 08:53 PM
NYC Civic
Jun 18, 2004 04:45 PM
