d15b7 engine potential
Old Feb 22, 2007 | 09:42 PM
seminole_wind's Avatar
Default d15b7 engine potential
Ive got a 94 civic dx 5 speed 2 door coupe with the d15b7 motor and i was wondering what the best thing i should do to make it a more potent machine. Does the d15b7 motor suck []? Should i get a Vtec motor and do a swap ? By putting on a intake and exhaust it would still seem thatvtec is the only way to go to make my car perform better. I do hear that these motors last forever though .
Old Feb 22, 2007 | 10:31 PM
riceburner700's Avatar
Default RE: d15b7 engine potential
[blockquote]lets start small, whats your budget?[/blockquote]
Old Feb 22, 2007 | 10:49 PM
about a thousand dollars
Old Feb 23, 2007 | 09:20 AM
do you really want to go with the hype and go with the mini-me swap? If it was me i would start with what a lot of guys and gals would tell you on this site, If you cant handle the hp and put it to the ground then its a waste. Start with some kind of performance suspension i herd ksports are a cheap awsome suspension, skunk2 is another good one but doesnt have adjusted damnpaning.
If you really want to go with engine performance first you could build a junkyard turbokit for around 1000 bucks for a 50hp gain or you could start with the basics and go with like you said. Intake,headers,exhaust,intake manifold/throttle body
Old Feb 23, 2007 | 09:31 AM
FlipHKD720's Avatar
keep saving up and boost that bitch use the $1000 you alreday have and start buying compenents of a turbo kit until you have everything, then put it all on at once. I/H/E will make a fun a daily driver, and suspension is a must, but if you want some real power, turbo is where its at
Old Feb 23, 2007 | 07:42 PM
ic892003's Avatar
can that non vtec engine handle boost??? even with a good tune ?
Old Feb 23, 2007 | 08:13 PM
Street Sniper's Avatar
Mini-me is going to be your best bet. You can turbo it but your head doesn't flow nearly as well as a vtec head.
Mini-me - $400
Tokico Hp shocks/struts/springs - $350
El cheapo intake w/K&N filter - $75
Short shifter + weighted shift ****- $100
That's $925 and a sweet ride.
Old Feb 23, 2007 | 08:20 PM
ic892003's Avatar
would a z6 head on the d15b7 block be good enough for boosting maybe 7-8 psi with a good tune
Old Feb 26, 2007 | 07:59 AM
Kedawei's Avatar
Z6 will be the one you want.
Old Feb 26, 2007 | 10:07 AM
Marty's Avatar
I suggest a Y7 head/Z6 intake manifold combowith a cam re-grind, lifters, retainers, springs, a excedy replacement clutch, stock flywheel shaved as far as it will go(13lbs or so)
