d16 potential
Here is some stock # for ya
92-95 Si D16Z6 5G - EH 1590 9.2 : 1 125 @ 6600 rpm 106 lb/ft @
5200 rpm
Intake valve diameter: 30
Exhaust valve diameter: 26
head cc's : 34.6
c/r :9.2
bore:75
stroke:90
single cylinder:397.61
total engine displacement: 1590.43
con rod lengthcon rod ratio:1.52
92-95 Si R Si R 2 B16A 5G - EG 1595 10.4 : 1 168 @ 7800 rpm 116 lb/ft @ 7300 rpm
Intake valve diameter: 33
Exhaust valve diameter: 28
head cc's : 42.7
c/r :10.2
bore: 81
stroke:77
single cylinder:396.78
total engine displacement: 1587.12
con rod lengthcon rod ratio:1.74
The lower compression on the z6 is better for turbo but the b16 has more horse power to start off with like 40 more hp over z6.With a built d16 you can achieve over 400hp.I say stay with you d-series
5200 rpm
head cc's : 34.6
c/r :9.2
bore:75
stroke:90
head cc's : 42.7
c/r :10.2
bore: 81
stroke:77
I have seen 600 to 650whp out of them built on vids, used to talk to a guy that had one built and boost dailr driven tuned and made around 450whp, and there is a thread floating around jeff evans forum of one that is bone stock and boosted making like 310whp and is daily driven.
