D16Z6
Old Mar 22, 2007 | 07:50 PM
Inev's Avatar
Default D16Z6
Well, I have found out that my mechanic put in a d16z6 when I expected the same engine as the car had, which was a d16y8.
Whats the difference and what would I be better off with?
Also, how much more work did they have to do to put this engine in?
Old Mar 22, 2007 | 08:40 PM
Kedawei's Avatar
Default RE: D16Z6
Z6 is better. Head and block are both better.
Work was the same.
Old Mar 22, 2007 | 10:04 PM
Default RE: D16Z6
I think the Y8 intake mani is better, but I'm not sure... I'd say keep the Z6
Old Mar 22, 2007 | 10:12 PM
danomatic93's Avatar
June 2010 ROTM
Default RE: D16Z6
D16Y8: 127HP @ 6600 rpm 107 lb/ft @ 5500 rpm Compression Ratio- 9.6:1
D16Z6: 125HP@ 6600 rpm 106 lb/ft @ 5200 rpm Compression Ratio- 9.2:1
I think, if I'm not mistaken, the Z6 gets much better gas mileage.
Old Mar 22, 2007 | 10:33 PM
finalimpact's Avatar
Default RE: D16Z6
d16z6>all y motors imo. i had yet another y7 toast near every bearing in the bottom end, this makes 4 y motors ive owned do the exact same thing. i want to know how your mechanic got the CAS wired up as the z6 has no provisions for it on the oil pump.
Old Mar 22, 2007 | 10:47 PM
Inev's Avatar
Default RE: D16Z6
Alright, called him up and got the information.
Y8 Head and z6 block
Old Mar 23, 2007 | 01:26 AM
Kedawei's Avatar
Default RE: D16Z6
Z6 head and intake mani are better I believe.
Old Mar 23, 2007 | 01:27 AM
Kedawei's Avatar
Default RE: D16Z6
ORIGINAL: danomatic93
It's actually quite a bit worse. The Y8 is designed for gas milage, while the Z6 leans more towards performance.
Old Mar 23, 2007 | 01:34 AM
June 2010 ROTM
Default RE: D16Z6
Well, the Y6 says it's supposed to get 31-38 mpg, but my Z6 gets 40 mpg hwy? Is that solely because of intake, headers, and exhaust? Oh well.
Old Mar 23, 2007 | 01:48 AM
Kedawei's Avatar
Default RE: D16Z6
40+ is not uncommon on them. Keep in mind also that your car is lighter than '96-'00s. The main difference is the cylinder head design. Everything else is fairly similar.
