Differences in B series
Old Aug 21, 2006 | 11:05 AM
Kedawei's Avatar
Default RE: Differences in B series
Yeah it is a bit confusing, because all those trannys share the same ID code. Yeah you'll want a Y80, S80, or a S4C/Y21 should do the trick also. It's kinda strange how the OEM LSDs are priced. If you order them by themselves from a website they'll charge you $1000. If you buy them w/ transmission they'll cost about $1000-1300 on ebay. But if you order them from an engine importer they'll only charge $300-$400 for them (with engine purchase). That's about all I can tell you, as I've only briefly looked into B-series platforms.
Old Aug 21, 2006 | 01:54 PM
Nail I3unny's Avatar
the reason i say SiR head is because its compatible with a lot more OE parts than the LS. you can use valvetrain and cams from ITRs, CTRs, GSRs, and any other SiR and get some pretty bitchin combos for N/A or FI (take your pick) and are great for dual duty (meaning achiving most possible power for the track while staying streetable). also it has a lower compression than any of the other 'type R' (meaning ending in R) so is the best for boost of the four. i know it also flows better than both the ITR and GSR and can be ported every bit as much as those two (im not sure about the CTR ports because i dont know **** about the engine or the head, and quite frankly dont want or care to).
S240161
Nov 3, 2005 08:35 PM
tru_dl
Sep 7, 2005 08:17 PM
00exinfl
EK Swaps
Mar 28, 2005 10:29 PM
phatek4
Dec 30, 2004 02:09 AM
