Disturbing Noise
Old Jan 17, 2006 | 08:21 PM
Clean98EX's Avatar
Default Disturbing Noise
So my car has about 127,000 miles and recently it has started making a strange noise. It's definately in the engine somewhere and sounds like a very fine whistling/whining sound that's making me nervous. I'm fearing that a bearing or the piston ring is going. I want to make sure that the engine is okay for this complete top end swap that i'm planning to do. any ideas would be awesome!!
Old Jan 17, 2006 | 08:53 PM
AgentofDarkness's Avatar
Default RE: Disturbing Noise
Did you check your belts? I think they make a whining sound if they are going bad.
Old Jan 18, 2006 | 07:25 AM
Talon585's Avatar
my accessory belts are making a low whining when its cold out, check those.
Old Jan 18, 2006 | 09:40 AM
Does it happen in a certain rpm range?
Old Jan 18, 2006 | 10:49 AM
Remmy's Avatar
water pump
Old Jan 18, 2006 | 03:27 PM
Clean98EX's Avatar
Well seeming that it's so Fu88ing cold up here, i hear it most when i first start the car and its running high to warm up. But i also here it in the top end when i shift. I would hope it wasn't the timing belt or pump because they were both changed at 90k.
apoplectic1
Oct 4, 2010 11:47 AM
MaximusFunk
Apr 12, 2009 11:48 AM
marcin69k
May 25, 2007 04:25 PM
Squeek
May 22, 2004 12:32 AM
green98lxsedan
May 15, 2004 03:35 PM
