Engine advice
Old Aug 21, 2008 | 03:17 PM
island__guy2008's Avatar
Default Engine advice
Ok guys, I have a 95 dx coupe with a sohc d15b7 non-vtec junk motor. I want get a new engine asap however I am completly new to swapping. Could anyone make a recomendation on which motor may be a good candidate to replace my stock motor, keeping simplicity in mind in regards to the installation. Cost is also a large factor......
Old Aug 21, 2008 | 04:01 PM
with cost and simplicity being the main factors, i'd recommend doing a mini-me swap. all you need is the d16z6 head, vtec solenoid, and ecu. everything bolts right up, except you have to remove the oil jet from the block which is simple, and you have to run a couple wires from the ECU to the vtec solenoid.
check out the DIY section for more info
it will give you as much power as a full d16z6
Old Aug 22, 2008 | 10:07 AM
Default oil jet?
Could you give me any more info on the oil jet removal? and you for sure need the ecu?
Old Aug 22, 2008 | 10:52 AM
croninc's Avatar
are you looking for more power?
Old Aug 22, 2008 | 11:21 AM
i have never personally done the swap.
i remember that there's instructions about the oil jet in the Mini-me Swap DIY in the DIY section. You may have to click something on the page that says like view all threads, or something like that.
if you want VTEC, and the power you'll get from the swap.
Old Aug 25, 2008 | 10:43 AM
arust45's Avatar
The most useful piece of advice would be to know why you want to swap another motor in. Is the motor junk as in you need to tow the car to get it moving?
________
BossIsHere live
Old Aug 25, 2008 | 12:34 PM
probably because the d15b7 is a junk motor. (performance wise)
Old Aug 25, 2008 | 01:33 PM
No the motor is in great shape its just that it is gutless. I want something better the problem is that i do not have a great deal of money to spend, I am leaning towards the mini me swap but I am still undecided.
Old Aug 25, 2008 | 11:49 PM
arust45's Avatar
The z6 head swap is a pretty good idea, but it will still be slow as hell. The fact that your tranny is geared for uber fuel economy does not help either. Check into nitrous in conjunction with the addition of vtac.
________
Avandia Settlements
Old Aug 25, 2008 | 11:59 PM
I wouldn't get nitrous if i were you. Instead i would look into some type of forced induction whether it be turbocharger or supercharger. Having to fill up your nitrous bottle periodically for $3-4 a pound just isn't that appealing. Sure, it costs less in the beginning and is easier to install, but in the end it will cost more than a turbo setup. The power you get from a turbo or supercharger is made by sucking in air, just faster than without the forced induction. But it's still just air, which is free... until they start charging us for that too.
