ENGINE DEBATE
i still cant figure out the best deal. its confusing. can someone give me some advice on what to do.
i was looking into doing a mini me and added all the prices on what i need. i have 98DX. Y8 head- - $250 Y8 Intake Manifold- - $100 Y8 Throttle Body - $100 Y8 Fuel Rail - $50 Y8 Fuel Injectors - $40 P28 ECU - $50 Head Gasket - $40 Intake manifold Gasket - $20 Throttle Body Gasket - $2 Exhaust Manifold Gasket - $20 Timing Belt - $20 96-00 Honda Civic EX Spark Plugs - $40 T3/T4 TURB- - $930 TOTAL - $1662 TOTAL W/O TURBO - $732 BUT. then all i have to do is like save a little more bucks to get...... b16 complete swap - $2000 b18 complete swap - $2700 h22 complete swap - $1500 . so let me know what you believe the best deal is. thank you. |
RE: ENGINE DEBATE
alright this has been gone over many of times so try the search
but ill give you my opinion on the whole deal i had a d series motor with v tech and was not happy with it, i found someone who would do the swap for cheap. i got the lsd tranny as well and it all came out to 3200 bucks i believe. this is with everything, the axels, edu, mounts, etc. i think this was def the best thing i could have done because i dont know how much longer my engine would have lasted. if i would have boosted the d series, i would have rebuilt my motor and sleeved it and then i would have boosted it. its just a preference, do you want dohc or sohc? do you want the turbo now or later? |
RE: ENGINE DEBATE
ORIGINAL: aryiman98civic alright this has been gone over many of times so try the search but ill give you my opinion on the whole deal i had a d series motor with v tech and was not happy with it, i found someone who would do the swap for cheap. i got the lsd tranny as well and it all came out to 3200 bucks i believe. this is with everything, the axels, edu, mounts, etc. i think this was def the best thing i could have done because i dont know how much longer my engine would have lasted. if i would have boosted the d series, i would have rebuilt my motor and sleeved it and then i would have boosted it. its just a preference, do you want dohc or sohc? do you want the turbo now or later? id like a dohc but i think it would be pretty awesome to beat dohc's with my single... i just want to beat some of the comp around my town. so if i mini me with turbo what all would i be able to beat? im not realy ready to spend s h i t loads of money. and if i f u c k up the d16. its only 300 for a hole new one. |
RE: ENGINE DEBATE
Mini me and boost.
RE: ENGINE DEBATE
mini me and boost will walk on those other swaps with alot less money spent
RE: ENGINE DEBATE
if you get the swap you have more room for expansion than witha boosted D
RE: ENGINE DEBATE
i would just by a d16y8 and drop that in there for about 600 bucks or convert to obd1 and drop in the d16z6 for 600 bucks and then use the rest for a bitchen turbo set up... then you will walk all over so many cars
RE: ENGINE DEBATE
mini me and boost. show that a single can beat dohc's.
RE: ENGINE DEBATE
Swap in a Z6 and boost it. Cheaper and better imo.
RE: ENGINE DEBATE
thanks alot. i was leaning more on mini me. so mini me it is. ill have pics later.
