engine help
Old Sep 17, 2005 | 05:35 PM
sy_82_nj's Avatar
Default engine help
i got a ef 4 spd with a new tranny. bout to add a 92-95 jdm d series vtec engine. i need to know whats all needed to make this swap successful. like the best ecu and can i used my old harness if i split it.
trying to add the basic bolt-ons before even trying to boost it. also what is the common msd set-up used on civics
Old Sep 17, 2005 | 06:36 PM
Kappa22's Avatar
Default RE: engine help
I wouldn't do the D15B1 swap. The fact that you're shoving a 5G VTEC engine into a 4G VTEC-less DPFI car is only going to spell lots of extra work. You should look into swapping in a DOHC (non-VTEC) ZC engine. It will literally drop into your car and bolt up to your tranny, etc, so all you need to do is get an 88-89 Integra 5 speed ECU (PG7) and convert the car to MPFI.
Old Sep 17, 2005 | 11:00 PM
sy_82_nj's Avatar
what is needed to swap dpfi to mpfi ?
Old Sep 18, 2005 | 04:21 PM
Kappa22's Avatar
fastncrazy1
Jan 4, 2010 05:55 PM
D16racerchick
Jan 3, 2008 05:15 PM
skibum853
Nov 18, 2007 09:40 AM
Benny Sim
Jul 19, 2005 07:43 PM
Jas10hon
Jul 4, 2005 10:35 PM
