engine revs it self
Old May 19, 2005 | 08:20 PM
MichiganRice22's Avatar
Default engine revs it self
welp i've had this problem before and i cant remember the the mech. told me it was something to do with the intake manifold or a dirty sensor. But i have a 95 honda civic, d16z6. The problem is when i drive than put the car into park yes its a auto it revs up and down a lot. i dunno what the correct termenology would be for that. if you've ran into this problem what steps did you take to fix this.
Old May 20, 2005 | 09:34 AM
fast93civic's Avatar
Default RE: engine revs it self
I had a similar if not exact problem. Check your linkage that is connected to your throttle body and make sure every thing is not too loose and not too tight, then check the actual throttle linkeage that is gong in to your fire wall of the car, make sure that it is fastened tight in there, I think you have to turn it like a key in order for it to lock in there.
rcgtsport
Aug 29, 2012 06:43 PM
tim.ocallag
12
Aug 5, 2011 06:16 PM
Platti J
Feb 6, 2009 03:16 PM
victor068
22
Mar 21, 2007 06:01 PM
joe383
Jul 11, 2006 07:10 PM
