engine swap
Old Jun 16, 2005 | 02:46 AM
skimmy_jimmy's Avatar
Default engine swap
ok i got yet another prolly dumb question. how much would it prolly cost to drop in a new engine? and what would be the best one to go for, a b18? and finally, what happens with your old engine?
Old Jun 16, 2005 | 09:13 AM
hondabboy's Avatar
Default RE: engine swap
Bolt-in swap,requires 99-00 Civic Si rear mount,requires wiring harness modifications are for the b18's
i suggest getting a b18c1 gsr motor. its not that expensive and its v-tec its specs are 170 bhp @ 7600 Redline: 8200 rpm, 128lbs-ft @ 6200.
the price would be around 1000-5000 its depends on what you find.
Old Jun 16, 2005 | 12:13 PM
Nail I3unny's Avatar
the GSR averages about 3000
Old Jun 16, 2005 | 03:25 PM
Replacement's Avatar
try to find a totaled GSR or Si and buy the entire car. Then you'll know you have everything you need for the swap... plus better suspension, brakes, and possibly the wheels if they are still alive. then you can part out the rest of the junk you dont use, most likely to a junk yard for nothing but its the easiest way to do a swap....
chbulldogs11@msn.com
May 27, 2011 09:05 PM
skibum853
Nov 18, 2007 09:40 AM
badboy4life
Sep 1, 2007 08:28 AM
Kingzlei
May 5, 2007 04:06 AM
silvr63vet
Dec 4, 2006 03:55 PM
