upgraded flywheel?
of course. it helps you tranny and also some weight reduction. if you get a light-weight flywheel i bet you you'll get about 1/2 of a second or more and if you get the whole set-up like the stage 3 clutch, pressure plate, flywheel you'll get a 1 second or 2 off your time.
It'll help you transfer power to the ground more effectively, and allow your engine to rev quicker. But be careful putting it on a poorly balanced engine, as it'll throw it off even more and probably cook the bearings within 30k (yes, those heavy-*** flywheels are part of the engine's balance).
