Fouling Spark Plug?
Old Oct 20, 2007 | 06:47 AM
kyleag89's Avatar
Default Fouling Spark Plug?
Hi I have replaced my spark plugs three times in the last month. They seem to keep burning out and turning black. The engine will then loose acceleration. Has this happened to anyone before?
Old Oct 20, 2007 | 05:35 PM
t34me's Avatar
Default RE: Fouling Spark Plug?
are you gaping(sp) correctly? What are your a/f ratios? you might be lean as hell
Old Oct 20, 2007 | 07:48 PM
riceburner700's Avatar
have you been messing with the computer at all?
Old Oct 20, 2007 | 08:06 PM
KoshaK's Avatar
If your spark plugs keep getting fried and you besically have a stock car, try getting a new brand name spark plug. Denso are great, will give you alittle more hp also. If you put these in and it happens again, id deffinetly take it to the dealer
Old Oct 21, 2007 | 04:32 PM
kyleag89's Avatar
They are gapped correctly, and I havent messed with the computer. I dont know what the a/f ratios are? I have tried autolite and ngk plugs.
Old Oct 21, 2007 | 04:58 PM
well are you burning any oil?
if it keeps failing then thiers a reason... #1 reason for failure so quickly is burning oil..... been thier done that...LOL
expetialy if its the SAME CYLINDER failing out...
but if they are ALL failing out.... then first thing i would replace is the coil and wires...........
and CHECK the timing! id check the timing first cause its cheaper
therobesons
Oct 6, 2008 11:47 AM
fast93civic
Feb 5, 2005 04:47 PM
bulletman0_0
Nov 8, 2004 11:17 PM
civic1.5uk
Jul 24, 2004 03:15 PM
GWhiz
Jul 3, 2004 11:00 AM
