Good Idea?
Old Aug 20, 2006 | 03:20 PM
t34me's Avatar
Default Good Idea?
D16A6 pistons in a boosted JDM D15B?? I want to put new pistons in while i have them out and are changing the rings, but having trouble finding ones that wont lower the the compression so damn much. I just dont know what the compression would be, ive read 10:1, but thats in a Z6. The JDM D15 has a more agressive cam, so i think it would be ok to handle that ratio, but i just wanted a couple opinions.
Old Aug 20, 2006 | 06:31 PM
riceburner700's Avatar
Default RE: Good Idea?
some people think that the d15b cam and z6 cams look almost identical, but why not run 10.0.1 compression? if the pistons are strong enough you wont have as much lag, and will still hasve really good bottom end
Old Aug 20, 2006 | 06:35 PM
Pete's Avatar
Man if i knew how to take apart my block to do this id have eagle and srp everything down there......i can afford the internals but just refuse to pay the insane labor.
Old Aug 20, 2006 | 06:38 PM
96civic285whp's Avatar
I agree if you have the money buy the good sh** so you only have to take it apart once, wish i was there so we could learn how to do it on your car, then perfect it on mine
Old Aug 20, 2006 | 09:48 PM
t34me's Avatar
Well, ill post pics as i progress through it, so it will kinda be like your there, but it will definitely be a learing experience for me as well. Luckily i found the post about the free helms manual and i did download it so ive been studying it every night
Old Aug 20, 2006 | 11:01 PM
Kedawei's Avatar
A6 pistons will stick out the block. Stock is your best bet for boost I'd think.
Old Aug 20, 2006 | 11:13 PM
t34me's Avatar
Ah, that is a wonderful thing to know! Thank you very much. Ok, so last question and this will be the final decision, should i clean up the current pistons and re-use them:
[IMG]local://upfiles/11033/D449A4D85D5B4418AF8E1CE202B27C42.jpg[/IMG]
or spend $80 and get brand new OEM D1678 pistons?
zuviex00
Jan 6, 2009 07:33 PM
cderalow
May 4, 2007 10:26 PM
89si
Mar 16, 2006 04:42 PM
TrAvMaNFTW
Mar 16, 2006 12:17 PM
skimmy_jimmy
Aug 25, 2005 12:10 AM
