GSR crank in LS?
Old Jul 16, 2007 | 08:24 AM
Lost's Avatar
Default GSR crank in LS?
Does anyone know if I can use a GSR crank in my LS/VTEC build? Is there any point, is the LS crank a weak point?
Old Jul 16, 2007 | 03:57 PM
k_dogg70's Avatar
Default RE: GSR crank in LS?
not sure if this helps, I'm doin the ls/vtec. i read the crank in the ls is a strong point. But that if doin a turbo setup u need to add the crank girdle.
I found one on ebay but it was for aB17 GSR, it will fit a b18 but.....
When adding the gridle it will be necessary to use different ARP journal bolts. I am uncertain where to obtain these, my machine shop is looking for them. I looked at ARP website but wasn't able to locate them in the catalog.
But for sure i've read high things about the ls crank, make sure it is turned and if u want have the edges knifed and new bearings of course!
Old Jul 16, 2007 | 05:15 PM
Pete's Avatar
Ive heard honda cranks hold up to 500 hp stock.
Old Jul 16, 2007 | 06:18 PM
Lost's Avatar
^ so have I, but I also heard the LS crank has to be balanced and polished and all this, so I thought maybe Id just skip all that and pick up a GSR crank.
Old Jul 16, 2007 | 06:48 PM
k_dogg70's Avatar
even if you pick up a gsr crank it needs to be polished and turned before putting it in, unless it is completely new. I would also imagine that using the GSR crank would neccesaite using the GSR connecting rods, caps, ect.to ensure proper fit? Not 100%, anyone correct me?
zerojett
Oct 18, 2011 03:01 PM
92gt50
Mar 18, 2009 01:51 PM
johnny
May 13, 2007 07:23 PM
djmatix
Oct 13, 2005 10:19 PM
