H22 in a '99 Civic?
Old Oct 15, 2007 | 08:12 PM
Exhausted's Avatar
Default H22 in a '99 Civic?
I've been searching around the internet for some info about swapping an H22 engine into a 99 Civic. I couldnt find very much here, but on another website, someone said: "The engine bolts in with the aid of a kit from compaines such as HASport, Place Racing, or HCP. This may be a little more expensive but the amount of work is comparable to a B18"
The reason I ask is because I can get an H22 for a bit cheaper, and the higher torque is a plus. I want to know whether it would be more practical to save a lil longer and just get a b18c or get the h22 while I can.
edit- just so you know, I'm looking at suspension replacement already, since mines going bad. I know I'm getting something stiffer this time around, so I don't think the extra weight of the engine is going to screw me over in the long run.
Old Oct 16, 2007 | 04:06 PM
Pete's Avatar
Default RE: H22 in a '99 Civic?
The weight difference is like 40 lbs. The H22 is a great motor, it is just a little harder to get it in. Its not THAT much of a difference......definetly better due to the 2.2 liter.
Old Oct 16, 2007 | 04:22 PM
Definitely go with an h22... I believe the weight difference is around 30 lbs for the block alone between an h22 and a b16 shortblock (so figure 50-ish lbs for the complete swap); that's not too much. And the added power and torque is, from what I've heard and seen, un-freaking-believable.
Old Oct 16, 2007 | 05:51 PM
Everyday Getaway's Avatar
If you aren't going to be putting it in yourself it's going to cost you a lot more for labor than a b series would.
I gotta say that your avatar is really offensive and completly inapropriate for a forum like this one dude...
Old Oct 16, 2007 | 06:02 PM
warner_ro's Avatar
go with the H22, and if you want a really good setup, use a B16 tranny with the H22 motor. sick setup. quick!!!
Old Oct 16, 2007 | 07:20 PM
Exhausted's Avatar
Alright, thanks for the info. I read somewhere that the h22 swap sometimes requires the AC to be relocated/removed. I don't have a lift or anything, so I probably will need to take it to shop. It's a shame because I want to do it myself (or at least be a part of the installation process,) because I want to learn more about cars in general.
Old Oct 22, 2007 | 11:30 AM
97civicdream's Avatar
I think were in similar shoes exhausted lol....im really excited to have a very hands on swap that allows me to become more knowledgeable of my dear civic at the same time and i think the h22 w b16 tranny is what id like to do im still waiting to hear some more advice from the forum on it tho but good luck with it!
shortkix
EG Swaps
Oct 9, 2007 02:47 PM
civicswaph22
May 5, 2006 03:52 PM
psycho_gyro
EG Swaps
Apr 25, 2006 07:03 AM
Graeme54
Jun 20, 2005 10:45 PM
