head gasket help
Old Jul 21, 2007 | 05:32 PM
yam2002r1's Avatar
Default head gasket help
does any one know where to get a head gasket that is thicker then stock. i am about to put the pm7 piston in with a zex or a skunk 2 cam. i am tryin to find a head gasket that about a .065 to .070 soo i get can the compression up to around 11.5 or close to it.
Old Jul 23, 2007 | 02:13 PM
antrmo's Avatar
Default RE: head gasket help
i may be wrong ,but in order to raise compression, you want less gasket,not more. but maybe the new piston size is compensating for your choice in gasket size. just a thought.
Old Jul 23, 2007 | 06:25 PM
jeff948594's Avatar
im pretty sure antrmo is right, if you want to raise compression u need to take your head to a machine shop and have them shave a few thousandths off, you want to decrease the amount of area not increase.
Old Jul 25, 2007 | 04:53 PM
yam2002r1's Avatar
with the new piston, it would put the compression to 12. to 1 i wantin it a lil lower soo i was goin with a thicker head gasket to put it a 11.5 to 1
slade8
Dec 6, 2009 06:23 PM
Crispy1
Apr 11, 2009 08:44 AM
95lsvtec
Feb 14, 2006 11:46 PM
civicpimpinsc
Feb 1, 2006 10:36 AM
civicpimpinsc
Jan 7, 2006 07:58 PM
