head job
Old Jun 14, 2007 | 05:42 PM
91civicsedan's Avatar
Default head job
i just bought a 91 civic 1.5l d15b2 pgmfi throttle body injection it broke t-belt and bent valves im going to pull head and send to machine shop to get repaired and new valve stem seals my question is im thinking of getting a 3 angle valve job done do you think its worth it or should i do any other headwork to pep up motor a little i not looking for a tire fryer just while its already apart why not any advice
a freind mentioned swapping in a 90s model si cam and would def help alot is this true and a good idea
Old Jun 14, 2007 | 08:41 PM
jeff948594's Avatar
Default RE: head job
did u try contacting the major autoparts stores? you could probably get a rebuilt head for about 300 or less after core, and it would have all new valve components plus its already machined and checked for compression?
rcgtsport
Aug 4, 2011 05:26 PM
HondaHowTo1
Oct 19, 2010 04:35 PM
ef9101
Jan 22, 2009 07:59 PM
Glebus75
Jun 28, 2007 08:00 AM
98brokeassvtec
Aug 26, 2004 11:38 PM
