HElP! ??d15b overheating
Old Oct 26, 2015 | 04:47 PM
Why So Serous's Avatar
Exclamation HElP! ??d15b overheating
hey guys and gals I have just done the water pump and thermostat as the water pump seal was broken and it was leaking ..
now its all done I over heat after driving for about 20 mins like over heat big time its steaming out into my overflow making a bubbling sound..
but if I put the heater on full blast its fine?
any ideas I really need some help thanks awesome people cheers
JDM first gen D15B 92 eg4
Old Oct 26, 2015 | 05:15 PM
AOL.COM's Avatar
Try a new radiator cap ...bleed the cooling system... make sure cooling fan is coming on at the right temp (225ish).....if you still get bubbles in the overflow, time for a head gasket
Old Nov 29, 2016 | 03:45 AM
Rlowman2016's Avatar
I'm curious ya said its a JDM d15b I got the same swap. What timing belt and water pump did ya use? I read it has to come from a d15z1 cause that motor and the JDM both use a 103 tooth timing belt as well as the same water pump
Booger
EK Swaps
Aug 9, 2011 10:11 PM
superballa22
Sep 18, 2006 05:06 PM
trebor_2005
May 19, 2006 01:40 AM
jwjknorr
Mar 20, 2006 09:53 AM
frewcivic
Jun 7, 2005 10:06 AM
