hey guys tech question here
Old Jun 23, 2006 | 10:24 PM
Teazrsnow's Avatar
Default hey guys tech question here
hey all ok so i got a 97 civic ex with some bad *** rod knock so i start searchin for a new short block this guy has a d16a6 motor he just had bored over .14 40k ago before he got a b18, anyhow i was wondering about what modifications i will need to do to use this block, i've done a little bit of reading and found that this is considered a mini me swap for people with the a6 stock and wondered if there are any problems i might encounter and if there will be any gain from using this block over a y8 block
Old Jun 23, 2006 | 10:48 PM
riceburner700's Avatar
Default RE: hey guys tech question here
they are basicly the same motor just one is obd2 and the other is odb1..
Old Jun 23, 2006 | 10:58 PM
Teazrsnow's Avatar
so nothing gained other than it being bored?? and also will this send an error code to my ecu then??
Old Jun 23, 2006 | 11:36 PM
Teazrsnow's Avatar
and again is there any modifying that i will have to do?
Old Jun 24, 2006 | 02:25 AM
97civicturbo's Avatar
Just get another block from an ex 96-00. It's not worth it to switch blocks just because the first one you found is from a different year. Search around and get one that will direclty replaces yours.
Old Jun 24, 2006 | 10:04 AM
finalimpact's Avatar
the a6 is a completly better engine than the y8. it has steel main caps and not to mention doesnt have the same oiling issues the 96+ y motors have. there is only 2 problems you will encounter.
1-lack of crank angle sensor on the a6 blcok
2-location and plug of thermal fan switch is different
you would end up having to use the y8 oil pump just to be able to keep the CAS. the fan switch problem is no biggie. also putting the y8 head on this a6 will bump the compression up some. personally i would make the a6 work, for sohc 1.6's i only choose the a6 and z6 all others have issues that i do not want to encounter.
Old Jun 24, 2006 | 11:14 AM
Teazrsnow's Avatar
thanks for your input guys...theres no oil squirter problem i need to take care of at all, i was reading something about that
Old Jun 24, 2006 | 06:00 PM
Teazrsnow's Avatar
sorry i should have put that in question form, is there any modifications that i will need to do, to make the v-tec work properly at all? i was reading that on some you need to pull out an oil squirter i just wanted to be sure im doing what i need to
lilfed857
May 16, 2014 04:39 AM
SpeedFr33k
Jun 25, 2008 06:22 AM
kick7_honduh
Sep 2, 2007 05:19 PM
truwon
Apr 5, 2007 10:06 PM
es2001civic
Nov 8, 2005 09:33 AM
