Honda Civic Swap ( D16Y7 to B18C GSR)
Old May 19, 2010 | 04:34 PM
carlos_herrera's Avatar
Smile Honda Civic Swap ( D16Y7 to B18C GSR)
Hello everyone! I am currently under taking on a civic swap, let me fill you guys in. I drive a 2000 Honda Civic, because I live in Canada its called the Honda Civic SE, but its pretty much A DX. It has the d16y7.. 1.6L sohc NON vtec. The Engine Iam putting in is the B18c GSR out of a 96 model. Now the company who I bought the engine from said All I needed for the swap was the following :
99-00 SiR rear transmission bracket
99-00 SiR Timing belt side post mount
94-01 GSR lower and upper rad hoses
94-01 GSR throttle cable
OBD2B to OBD2A conversion harness.
I bought all of that and Yes they do come in handy. Now the Problem is that I read somewhere because my Civic is a Non Vtec version, I need the wiring harness From a Civic with a Vtec so the Harness from the GSR will work. Can anyone please msg me back and give me some points or tips. Thank you everybody for your time!
Old Jun 17, 2011 | 11:03 AM
ShockerBoy's Avatar
Question
Carlos, i have the exact same car and question about having to use a harness from a vtec civic, just wondering if you had found out if your obd2b worked with the gsr? anybody at all know, i just cant find the answer to this question!
Old Jun 17, 2011 | 04:41 PM
I kept my old harness but I used the ECU that came with the car. I also bought a conversion harness. OBD2B to OBD2A conversion harness
Found it on ebay for cheap too! make sure you check ur alternator fuse I had that problem too. let me know how it goes!
Sorry I meant used the ECU that came with the engine!
Old Jun 19, 2011 | 06:03 PM
ShockerBoy's Avatar
Thumbs up
so i found out; to save my self adding in new wires, like the knock sensor, vtec silanoid..... i have to buy a 99-00 si/ex wiring harness, which is a d16y8!! then the obd2b to obd2a jumper and ill be golden besides
having to extend a few of the sensor wires and swap them with the sensors from the jdm. i found a site with a awsome material list and plug swap list some dude put together while doing the swap! hope this helps anyone!! the f@ckin time a fella puts in on research is crazy,
anyone else with some helpful hints or tips, problems you've came across, it would be greatly appreciated!!, my swap is going to be a jdm 98+ b18c type r swap into a 00 civic se
here is the link for that list
http://www.honda-tech.com/showthread.php?t=1008225
Old Apr 17, 2014 | 05:15 PM
R-SPECS98's Avatar
thank you your link was very helpfull
Aaron A Archer
Dec 3, 2011 03:38 PM
civicteam
Jan 28, 2010 06:53 PM
legal
Jan 26, 2008 09:35 PM
mentaldis0rder
EK Swaps
Mar 17, 2006 04:56 AM
Druvochsky
Dec 10, 2004 05:51 PM
