i think im idleing too high...?
i have a b16a and i just finished changing the gasket for the exhaust manifold, i have a header, but it is like 4-5*c outside but i started it after not being started and it idled at like 1600 then after a rev it dropped to 1500, then dropped to 1250-1000 after it warmed up, is that normal for a vtec motor when its cold?
It's normal. My '95 EX, '99 EX and friends '91 Si all initially idle around 15-1600rpm at start but then drop slowly as the car warms up. Normal operating temp idle is anywhere from 500-900rpm for them and as it should be for these cars.
If you car continues to idle 1000rpm or above while at operating temp you may either need a mild tune up or simply need to adjust your idle screw.
Also make sure there are no loads on the motor such as A/C, headlights, etc..
It doesn't matter that they have v-tec. If it's freezing or below, I usually wait at least a couple of minutes before going anywhere. If it's reeeally cold I'll take my time and let it warm up for a few minutes. If I'm in a hurry, I'll get going but I'll coast in neutral as much as possible and wont rev up too high until it starts warming up.
