IM and TB or Valve springs/ retainers?
A correctly set up fuel pressure regulator may help a little but is not necessary, And assuming your bottom end is ok you wont need rings or rods for bolt on mods like TB/IM.
Great, love NA cars and hope this whole project will give me some good power!!! When i have this head and stuff installed, can i keep my current timing belt? It only has 35k or so on it.
Funny but i still have to drive to school everyday!!! Here a question for ya. I've heard that a Z6 head on a Y8 block will loose some compression. What head gasket would be the best if i want to regain the compression? or even gain some!
I would do the Intake Manifoldm because when you remove the head, ya gotta take off the IM too. My rules say "Never take a stock part off, and put it back, if ya can replace it with a better aftermarket part, that will create more power.
Yeah, the z6 combustion chambers are a bit bigger. About half a point worth.
Some suggestions on head gaskets...
OE Honda metal 3-layer, A’pexi 1.1mm (.043”) PN 814-h101, A’pexi 1.5mm (.059”) PN 814-h102, or Greddy 2mm (.079”)
Obviously the thinner you go, the higher the compression. Where are you trying to get to compression-wise?
I'd like to keep the compression above 9.5. Would it be recommended to let this setup wear in for a while? Would like to do a dyno run before and after to see the diff.
