IM and TB or Valve springs/ retainers?
ORIGINAL: Nail I3unny
im not sure if this is exactly right, but if you take a d16b7 block, d16y8 head, d16a3 pistons, and d15z1 pistons and you will get a crazy 17.4:1 compression ratio. its more like 17:1 with the z6 head.
anyways...moral of the story...all d series parts are interchangeable. thats a good general rule of thumb when it comes to building Ds.
yes you can use the y8 cam gear although cam timing will be affected if i remember correctly 4 deg either way. and you will have to use the y8 dizzy(asuming your obd2) you will also have to hack the dizzy mounting legs to allow you to bolt it up(a little trimming).
I would quess that a tuner shop would know this and be able to handle it, right? I know everyone ask this but what kind of hp gains could i see with:
-Z6 Ported and Polished head with 3 angle valve job,
-Y8 stage 1 cam
-skunk2 IM
-62mm TB
and of course I/H/E and VTEC controller
-Y8 stage 1 cam
-skunk2 IM
-62mm TB
ORIGINAL: AgentofDarkness
Anyone else think that a 17:1 compression ratio is really high?
to the guy who pointed out that its not all true...yeah i know. general rule of thumb = in most applications. so in most applications D series parts are interchangeable.
DjHagios
Jul 29, 2010 04:38 PM
hondaimports30
Sep 24, 2006 10:23 AM
