ive got about $1,000.00
Old Apr 23, 2005 | 11:11 AM
jwsimons's Avatar
Default ive got about $1,000.00
what would be the most bang for my buck, ? do a complete valve and spring and retainer r&r? the main thing for me is (4 those who dont know, i'm replacing d15 w/ b16a in my '88 hatch) i want to do the most productive things i can with the motor out, ie; i already have new clutch kit(hopefully the right one?) i'm deffinately installing new oilpump and pan gasket, i.m. gasket, is there anything else to do to the lower block other than pump and gasket? is a thin head gasket safe, and worth the effort? do really gain compression with thin gasket? not much time left
Old Apr 23, 2005 | 12:06 PM
blackeyes's Avatar
Default RE: ive got about $1,000.00
go with blox stage 2 cams, and retainers and springs. that might leave you with about, then try to get some headers, or an intake. ill tell u what though, when i got my b16 and i had a g i got headers, intake, and an intake manifold, and brake pads(needed brakes) anywas all that was $820.
Old Apr 23, 2005 | 11:23 PM
sacicons's Avatar
with stage 2s, youll need springs and retainers. get those now, and maybe a set of type r valves, that way, you can add cams later without any worries.
Old Apr 24, 2005 | 01:03 PM
jwsimons's Avatar
yeah! ordered yesterday. springs, retainers, valves, waterpump, oil pump, t-belt, thin head gasket, hondata im gasket, gasket set for the rest, crank seal, cam seals, and pretty soon i'll have the cam also. dont know the cost just yet, the guy is workin on it monday, but i think we may be using all crane stuff. did i miss anything? or have i just about got it all?
Old Apr 24, 2005 | 01:12 PM
sacicons's Avatar
sounds like youre on the right path. youll be doing great when you get it all done.
Old Apr 24, 2005 | 01:22 PM
LEVIII's Avatar
I was gonna say water pump, but you already got that
We all know how fun those are once the motor is in.
Old Apr 24, 2005 | 04:04 PM
jwsimons's Avatar
thanks guys, if you wake up in the middle of the night and think of something else.. lemme know, k.
hey sac. did you find out anything more about that clutch? i have not broke the seal yet, in case i gotta take it back.
(i should change thread subject and add "but i'll end up spending 2-3,000.00)
Old Apr 24, 2005 | 05:23 PM
sacicons's Avatar
i think youll want to make sure and get the right one by getting the 90-93 teg one. the swap you have s a cable tranny one, right?
Old Apr 24, 2005 | 06:21 PM
jwsimons's Avatar
it appears to be, looks almost the same as the d15 thats in there now, but really i have no idea what to look for. the new does have an ark where a cable would terminate, below a bracket.
ORIGINAL: sacicons
Old Apr 24, 2005 | 08:18 PM
sacicons's Avatar
see if you can post a pic of the front of the tranny, and someone will let you know.
