JE pistons
Old Aug 22, 2009 | 08:52 PM
yosvani's Avatar
Default JE pistons
do u guys have any idea how much these pistons can withstand?
http://store.jepistons.com/149178.aspx
cuse i wana run boost and want HP to be anywhere from 300-400? can these take it?
Old Aug 22, 2009 | 10:16 PM
write the company and ask them and also you need to look into rods...and much more
Old Aug 22, 2009 | 10:29 PM
yosvani's Avatar
i know i wana go eagle rods.. i wont need cams at 300 hp would i?
Old Aug 22, 2009 | 10:45 PM
are you running all motor.or..turbo..or ..nos..?
what im saying is how do you plan on making 300hp?
and what turbo are you gonna use..and what engine
Old Aug 22, 2009 | 11:07 PM
yosvani's Avatar
ok o shoulda said this earlier i have the d16y8 i wana do turbo and in not 100 percent sure on a turbo yet im still looking around
Edit: mayb this 1 http://www.turbobygarrett.com/turbob...R_466541_1.htm
Old Aug 22, 2009 | 11:16 PM
the oil pumps on d16y8 arent that good..
for a sohc to hold that much hp and not blow its gonna take some work
get head ported polished,new seals,valve job, upgrade cam(will help getting to 300hp), head studs, upgrade valve springs and retainers.upgrade pistons, piston rods. then from there you will need a tuned ecu. a good full turbo setup. then you will need to upgrade the motor supports.
and exhaust. upgrade the clutch possibly also the axles.(would have to see how much torque you will be producing)
Old Aug 22, 2009 | 11:20 PM
yosvani's Avatar
u think the skunk 2 cams will take the power?
Old Aug 22, 2009 | 11:21 PM
there are different types.. and yea they should..
i believe crane cams are also a good choice..
and that turbo is to small^
look into more like a t3/t4
Old Aug 22, 2009 | 11:33 PM
yosvani's Avatar
how much hp can the stock cams take because i was looking and the skunk2 cams are legal emission so i dont know if i wana mess with that...
Old Aug 22, 2009 | 11:35 PM
florida dont have emissions
upgrading the cams will help deliver that 300hp you want.
it will let the valves open more to let more boost in
