lotta smoke :(
Old Sep 29, 2006 | 12:11 AM
mt biker's Avatar
Default lotta smoke :(
ok so..... my 91 civic dx (16 valve sohc) engine is buring oil. the spark plug and exhaust port on the 4th cylinder are all oily and gunked-up. im takin the piston out (hopefully tomoro if i have time, if not then ill have to wait till next week sometime) to check the rings, piston and cylinder wall. i've already checked the valve seals and they seem ok but im gonna put on new ones anywaycus i have some (other wise i'd just throw them out).
if anybody has any ideas feel free to let me know
oh and by the way the whole car has over 300 thousand kms on it so yea.....
Old Sep 29, 2006 | 08:07 AM
Default RE: lotta smoke :(
Have you tried running a compression test? I would start there before tearing into the block
Old Sep 29, 2006 | 11:57 AM
mt biker's Avatar
ya the compression in the 4th cylinder is slightly lower than the rest of em.
Old Sep 29, 2006 | 12:47 PM
ORIGINAL: mt biker
What were your numbers?
Old Sep 29, 2006 | 06:23 PM
mt biker's Avatar
they were all at 153/154 except the 4th of course which was a little lower by about 5/6
im taking the piston out next week to check the rings and then ill put it all together and run another compression test.
Old Oct 5, 2006 | 06:41 PM
mt biker's Avatar
piston, bore and rings are in the same condition as the others. just checking pricing and other options
Old Oct 8, 2006 | 05:51 PM
mt biker's Avatar
so oil is coming up past the rings on the 4th. im gonna put new rings on all pistons and hone the bores put it all back together and see how she runs.
Old Oct 8, 2006 | 11:16 PM
Remmy's Avatar
Your rings are going out. Run a leak-down test to find out which ones.
Old Oct 8, 2006 | 11:23 PM
bigmikew1's Avatar
i didnt check and i was drivin w/ no oil then my father put too much oil in it. and it was smokin a lot. all dat messed up my engine. instead of gettin it fixed i got my mechanic to find me a new stock engine. it was a lil bigger. went from 1.5L to 1.6L cost me $1000.
ScoobyAddict14
Aug 5, 2005 10:35 PM
titoe
Apr 28, 2005 02:11 PM
titoe
Apr 26, 2005 09:17 PM
mx6s girl
Mar 28, 2005 05:26 PM
niteryder
May 29, 2004 11:35 PM
