LS block, B16 head
Old Aug 28, 2005 | 07:26 PM
Nail I3unny's Avatar
Default LS block, B16 head
k well...ive been looking into different combos i could potentially do. right now im looking at an ls block (because the stroke islonger than the gsr) and put on a vtec B16 head. anyone have any advice on thi sor any other suggestions?
Old Aug 28, 2005 | 07:49 PM
LEVIII's Avatar
Default RE: LS block, B16 head
I dont like that as much as the GSR for a couple reasons.
1)Longer stroke although is more displacement is not as high rpm friendly. In the DSM/Evo world alot of guys actually destroke their cars and then bore them bigger, unfortunatly we cant do that cause of the open deck design we have.
2)The GSR has a main crank girdle which the LS does not.
3)The GSR has oil squirters which the LS does not.
In the end, basically a GSR block is ready to stand up to the high rpms the head is and the LS block was never really meant to rev that high.
I am not a big fan of the LS VTEC but for the budget route you really cant argue with it a whole lot. Although it sounds like you are going to chose between the 2 and want the best one.
Old Aug 28, 2005 | 08:32 PM
sacicons's Avatar
also, the gsr motor is factory zero-balaced, and the LS is not. thats why a dohc vtec can rev to 8k+ daily with no problems, but an LS/VTEC will eventually eat itself. and usually, theres nothing left when it gives up.
Old Aug 30, 2005 | 03:43 PM
k guess im still going with the GSR w/ the b16 head then
Old Aug 31, 2005 | 09:13 AM
hondabboy's Avatar
yup your going to feel the difference between heads. trust and believe
Old Aug 31, 2005 | 10:12 AM
LEVIII's Avatar
Are you going turbo? Casuse the GSR with a B16 head is a great choice for turbo cause it will slightly lower compression but if your not then you will lose some power there.
90CrX_Si
Nov 13, 2006 02:28 PM
lilpooh21186
EK Swaps
Sep 4, 2006 11:59 PM
Skrapdoggydog
Aug 24, 2006 10:29 PM
S.aelee I.nside
Mar 27, 2006 11:54 AM
outlawzz23
Jul 10, 2004 04:52 PM
