LS or Vtec
Old Mar 16, 2005 | 11:18 AM
grncivicvtec's Avatar
Default LS or Vtec
I have the LS non vtec, Should I put some stage 2 crowers cams and valve train or get a vtec head??
Old Mar 16, 2005 | 08:46 PM
finalimpact's Avatar
Default RE: LS or Vtec
what are you looking to get? i have seen ls-vtec's push about 170ish whp and 150ish wtq upon proper assembly. you wont touch that with crower's.
Old Mar 17, 2005 | 11:14 AM
umm, well I would like to get a vtec head, but then a nasty lswould be nice, and then turbo later on this year, either way its goin to have turbo around the end of this year maybe sooner.
Old Mar 17, 2005 | 10:32 PM
sacicons's Avatar
your cam needs are way different with a turbo, so hold off on the cams until its boosted, or get some turbo profile cams. stay away from LS-Vtec. there are quite a few reasons, but the main one is that your block isnt made to run to 8000 rpms for very long. it just wont last. a properly tuned turbo will last awhile on that motor as long as you take care of it and dont run the hell out of it all day every day.
Old Mar 18, 2005 | 09:31 AM
What if I did not do turbo and built my ls, if i build my head, port and polish a intake manifold i have layin around and get a header, i should be good or would my block not be able to handle, it?? I heard it has a good block and can handle runin 8 grand. with built head.
Old Mar 18, 2005 | 08:27 PM
sacicons's Avatar
it can handle 8k, but not all the time, everyday. it will fatigue the parts enough to cause severe engine failure. DOHC VTEC motors are zero balanced from the factory, non-vtecs are not. so that little bit out of balance that the motor has could cause severe vibration at high rpm. an all-motor ls motor can be a lot too handle for a civic. a good set of cams, an aftermarket IM, a good header, and some mild headwork can make a beast out of it. with a torque curve that would make an h22 blush. (of couse it wont have the top-end charge, but a lot can be said for mid-range power.)
Booger
EK Swaps
Aug 9, 2011 10:11 PM
88civicjordan
Mar 2, 2006 09:12 PM
ryantann
Feb 21, 2006 09:50 PM
mahmi
Aug 25, 2005 09:39 AM
kcmercedes
EK Swaps
Sep 24, 2004 11:05 PM
