NEED HELP!!!!
Old Dec 20, 2005 | 12:29 PM
fastcivic160's Avatar
Default NEED HELP!!!!
Hey everyone, i need some help with a problem that accured last night. I was just drinving along, and all of a sudden i hear a pop, and the tone of my car changed, to a rumble, it kinda sounded like i was running straight headers. so i pulled ova and check to make sure my exhaust was still on and it was, then i poped the hood, and saw the problem one of my spark plug wires was haning out and the spark plug was missing, it must have shot out and dented my hood from the inside, the spark plug cover was gone. I then went to wal-mart to get a replacement spark plug and some tools to change, cuz it was like 1 in the morning and when i got back to work on my car the spark plug wouldnt even screw in, and i dont know what is wrong with it. If anybody can help me that would be awesome just leave me a message on here thanks
Old Dec 20, 2005 | 12:39 PM
Chimera02EX's Avatar
Default RE: NEED HELP!!!!
might have stripped the threads when it shot out. dunno on this I'd prolly take it to a mechanic you know you can trust.
Old Dec 20, 2005 | 12:50 PM
StifflersMom's Avatar
Cat Fuсker
Ummm...that could happen if you didn't screw the old plugs in all the way or somehow the exhaust valves got stuck...I don't get it...
anyhow I would guess that you're looking at a new cylinder head...its definitly stripped
Old Dec 20, 2005 | 02:07 PM
AgentofDarkness's Avatar
The guy that put your spark plugs in might not have torqued them correctly. The spark plug would be loose and the cylinder pressure would make it pop out of the engine, stripping the threads on the cylinder head in the process. My teacher warned us of this when he was showing us how to install plugs.
Old Dec 20, 2005 | 05:23 PM
thank yall so much for the help, do yall know how i can replace the part my self or would yall recommend me take it to a shop. Is there away i can put a helicoil in there with out removing the head or would i need to remove the head. If yall can let me know on this one to it will be greatly appericated thanks so much
Old Dec 20, 2005 | 07:23 PM
Cat Fuсker
I say, take it to whoever changed the sparkplugs and make them pay...
Old Dec 20, 2005 | 08:01 PM
Micter's Avatar
A helicoil should do the trick. I had a simular problem with a bug.
Old Dec 20, 2005 | 08:44 PM
for the helicoil would i need to remove the head or can i just do it with the head still in tact, on and for your information im the dumb *** who changed the spark plugs and ur right i am payin for it hahahaha, thanks for all the help tho
Old Dec 20, 2005 | 09:01 PM
Micter's Avatar
It depends on how much room you have to work with.
Old Dec 20, 2005 | 10:04 PM
Noob question but what is a helicoil. I'm thinking that its when you weld in a circular piece of metal that has threads into the spot where the threads were stripped.
