Needed: People that know what they are talking about
Old Sep 13, 2006 | 03:01 PM
Kedawei's Avatar
Default RE: Needed: People that know what they are talking about
Try other online parts stores?
Old Sep 13, 2006 | 05:42 PM
t34me's Avatar
very limited number of places that carry these pistons at a price i can afford, so i ordered the vitaras
Old Sep 13, 2006 | 11:07 PM
Kedawei's Avatar
Should be -1.8mm out of the hole with those. Not sure if that will be a problem... but compression will be about 9.7-9.8:1.
Old Sep 13, 2006 | 11:13 PM
t34me's Avatar
??? These sit .01 in the hole and compression is 9.18:1
Old Sep 13, 2006 | 11:22 PM
Kedawei's Avatar
207.45mm (block) - 137mm (rod) - 42.25mm (half crank stroke) - 30mm (vitaras compression height) = -1.8mm
Old Sep 13, 2006 | 11:23 PM
Kedawei's Avatar
Nevermind, my source was wrong. Comp height is 28mm on vitaras. .2mm in the hole.
Old Sep 13, 2006 | 11:25 PM
Kedawei's Avatar
Nvm lol, we're both wrong on compression. It's 8.83:1. Blah, I hate when people don't know how to make measurements and post inaccurate info. 9.06:1 with D16Y8 two layer headgasket though. (static)
Old Sep 13, 2006 | 11:30 PM
t34me's Avatar
no worries, but god, you scared the **** out of me, ive ran the numbers a dozen times and i thought i had done somthing wrong.
?Why does compression go up with thicker gasket, the Z6 is thinner right?
Old Sep 13, 2006 | 11:34 PM
Kedawei's Avatar
Nah, the two layer is a bit thinner. Lol sorry to scare you. I was going off this site http://www.knology.net/~jediklc/dcalc.htm because Zeal was down at the time I posted that. Apparently it's compression calculator and piston info are incorrect. Zeal seems to be the only good one around (even though they have the deck height wrong for D15 blocks).
Old Sep 13, 2006 | 11:38 PM
t34me's Avatar
well crap, already got the HG, oh well, ill make it work. You know anything about which would be a stronger rod, JDM D15b or D16A6
