oil leak
Old May 30, 2007 | 05:23 PM
cmansmith19's Avatar
Default oil leak
i have a 97 honda civic dx with a oil leak onlythe realproblem is i dont know where the oil is coming from. i have already replaced the oil pan gasket and am sure this is not the cause of the problem. any sugestions?
Old May 30, 2007 | 05:25 PM
MY99SI's Avatar
Default RE: oil leak
did you get the bolts good and tight? and where is the oil comeing from what part of the engine?
Old May 30, 2007 | 05:40 PM
yes the bolts are tightit seams to be leaking between the motor and the clutch but its looks like its running down the block i just dont know from where
Old May 30, 2007 | 05:51 PM
and no its not the oil filter
Old May 30, 2007 | 10:19 PM
MY99SI's Avatar
cam seal possibly
Old May 31, 2007 | 05:06 AM
cpl rampage's Avatar
if there is oil on the engine above the flywheel then it can be one of three things, valve cover seal, cam seal, or a head gasket.
if ther is not oil on the engine above the flywheel, it can be one of three other things, oil pan gasket, rear main seal, or input shaft seal. i assume u have to add oil to the engine, and not the tranny? if so then you can ignore the input shaft seal, because u would be leaking tranny oil.
Old Jun 4, 2007 | 05:46 PM
its a standard
theRDRman
Nov 28, 2011 04:18 PM
shadow_93
Dec 28, 2009 11:26 AM
oilltd
Jun 10, 2008 04:06 PM
mokijo2
Dec 27, 2007 12:11 AM
