oil leak
Old Mar 25, 2008 | 10:35 AM
javon's Avatar
Default oil leak
i have oil leaking through the bolts that hold the valve cover on what do i need to replace to stop this leak. there is no oil leaking from around the valve cover.
Old Mar 25, 2008 | 01:28 PM
importcivicus's Avatar
Default RE: oil leak
i would get some new washer mounts. They have a rubber seal inside of them and they do have a tendenic to leak if they are not tight or they are cracked and brittle due to the heat of the engine.
Old Mar 26, 2008 | 05:26 AM
Blue Canon's Avatar
Ya, go to the Honda dealer, you should just be able to get the seal, they take some work to pop on though, you'll see when you get the bolts out. MAKE SURE YOU TORQUE THEM TO SPEC! They are very easy to break, especially if it's an older civic.
theRDRman
Nov 28, 2011 04:18 PM
shadow_93
Dec 28, 2009 11:26 AM
oilltd
Jun 10, 2008 04:06 PM
mokijo2
Dec 27, 2007 12:11 AM
