Oil Leak on Rear of the Engine
Old Oct 19, 2005 | 07:16 PM
vignesh4u's Avatar
Default Oil Leak on Rear of the Engine
I am planning to buy a 2001 Honda Civic with 40000 miles on it and got it inspected thoroughly today. I was told that "there was a minor oil leakage" @ the rear of the engine. The mechanic said he could not say if it was a problem with the "rear seal" or not without removing all the components of the engine [ with a labor cost of 500-600$]. Has some one experienced such a problem and what is the likelihood of this being a rear seal problem [ or would it just be a "valve cover gasket" problem - read this in an article ?] . Shoud i go ahead and pursue this car for buying or is it too much of a risk to take ? [&:]
Old Oct 20, 2005 | 09:09 PM
Kappa22's Avatar
Default RE: Oil Leak on Rear of the Engine
Just to clarify... by the "rear" of the engine, do you mean the flywheel end?
Old Oct 20, 2005 | 09:29 PM
StifflersMom's Avatar
Cat Fuсker
if you knock off a few grand from the price because of that leak, I'd go for it
Old Oct 20, 2005 | 10:44 PM
vignesh4u's Avatar
Hi,
Thanks for your replies. I am not sure if its the flywheel end, would clarify that info. by tomorrow. In the mean time, I asked the seller tp take it to a Honda Dealer & inspect the "oil leak @ the rear of the engine" . The seller told me that the Honda Dealers found a "Loose Oil Filter" and was fixed. I would like to know, if the "loose oil flter" could be a genuine cause of a oil leak @ the rear of the engine or is it some thing that I shouldnt concur to? The asking price for this Civic LX [40000 miles, 2001] is $10,900. The seller is not willing to reduce the price by a max of 10, 400$. Would like your feedbacks on these.
Thanks
Old Oct 21, 2005 | 12:17 PM
Kappa22's Avatar
It's possible that the leak was caused by a loose oil filter, but that would mean that whoever did the last oil change was a complete idiot.
Old Oct 21, 2005 | 02:42 PM
Cat Fuсker
ORIGINAL: Kappa22
Yep...either that or something there could be warped
Dwack1992
Apr 8, 2013 04:05 PM
theRDRman
Nov 28, 2011 04:18 PM
oilltd
Jun 10, 2008 04:06 PM
mokijo2
Dec 27, 2007 12:11 AM
