P29 pistons Fit in a 99 civic-- cam ?
Okay this is a question to all you guys... I was thinking about buying a spare motor to work on in the garage.. I heard that the p29 piston from a acura... .. Question is those pistons and the stock pistons the same bore?
Some one was saying the pistons are like 11.1 compression is that right?
Stock HP 99 LX civic is 110hp?
with high compression pistons and a intake manfiold off a ex civic.. would that make it around 140hp?
Does anyone run cams that is smog legal? if i put a cam i should be at 165-170?
