plugs,cap,roter,wires?..or just plugs
ok..iv had my civic for over a year now, before i bought it, it was leased and dealer maintained for 2 years, then it sat in the lot for like 3 years till i bought it...i am going to change my plugs, but should i change wires,cap and rotor too? or should i just wate till they actually NEED to be changed? ...but forsure im changing the plugs,i just want to no if i should do all the other or will it make a difference?
I hated my MSD wires the were tarable they lasted on the car for 4 days before I replaced them with Accel thundersport+300's and they are 3 years old and great. They pulled apart and i had a miss with them(it was probably just my luck though). I would stay to the stock plugs unless you are boosted or run high HP numbers otherwise there is no point it will just hurt you in the long run our motors rely on a proper heat and with nothing to bring that heat higher than stock why cool it down. Also I like my Accel wires but my Nology wires on my DSM are god but they cost. Also NGK has really good wire for your application which would suit you great. I would do it all at the same time also do a fuel filter while your at it. Good luck.
2000CivicSIcoupe
Feb 21, 2007 09:56 PM
civic_x
Feb 16, 2007 02:04 PM
larsenracing
Mar 28, 2006 09:58 AM
mill$civic
Nov 18, 2005 09:52 PM
cvcman
Jan 17, 2005 08:25 PM
