problems with turbo/engine/anything else
450's tick whether they're running 100% correct or not. What Tyler is experiencing though, is the normal tick, times a baggilion. I'm thinking that maybe the resistor box is out, and its causing the injectors to fully open all the time, rather than firing when their supposed to, in turn causing a louder tick..
ORIGINAL: Forty04
The box is wired just fine. I went over it with a fine tooth comb after soldering everything together. If it were the wiring, it most likely wouldnt be running on all 4 cylinders anyway.
well the DSMs are high impedance, and the resistor box is supposed to bring the DSMs down to the Civic's necesarry lower inpendance, so if you are getting too much fuel, the injecotrs might still be running at high impedence, which would mean the resistor box could be bad. And Tony, while everything may be wired correclty, perhaps the box itself is bad.
just tryin to help
so take it easy if i'm really far off
just tryin to help
fixed the ticking noise. got another resistor box and it went away. the car will now just fire up and then not even idle. it just dies. i talked to street today and he said it could be the chip, i told him what was going on and he said that the same thing happened to him when he had a bad chip. tomorrow i am going to kalamazoo to see the tuner and then i will be getting another chip and making sure my ecu is good. ill update tomorrow.
tallyimports
Apr 15, 2006 07:29 PM
pimpingitup239
13
Jul 7, 2005 07:48 AM
