Quick question
Old Jun 18, 2006 | 06:07 PM
Belmont's Avatar
Default Quick question
On the dip stick, about where do you want the oil line? My dip stick just has 2 holes in it at the bottum part. Im guessing you want it to be in between the two, correct? I just changed the oil and I put in about 3.4 quarts which is what the manual recommends...
Old Jun 18, 2006 | 06:50 PM
ef4life's Avatar
Default RE: Quick question
between is good, a little higher won't really hurt
Old Jun 18, 2006 | 07:32 PM
pWnEdU's Avatar
Yep, but just to add: overfilling is just as bad (if not worse) than underfilling because if you overfill a lot (nothing you're likely to do) your rods will act like egg beaters and aerate your oil and byebye motor.
But we're not talking about a little bit, this is if you add a FEW more quarts than specified, not just a little bit on the dipstick like you're talking, so don't be all paranoid LOL.
Old Jun 18, 2006 | 07:49 PM
Belmont's Avatar
Thanks guys, yea i was asking because the dealership did my first oil change, and the oil line was way over the top dot.
THE_CRIPPLER
Dec 6, 2005 08:26 AM
scottex
Jul 18, 2005 04:58 PM
fastman90
Jun 26, 2005 12:59 PM
Smeghead009
May 31, 2005 12:02 AM
02CivicEX
May 4, 2005 07:03 PM
