rebuilding
oh ok...so u guys think i should still buy the head gasket kit for the d15 and see what will work with both..the head gasket kit i was told will come with all of the gaskets i need for the whole motor...
i found some decent sites that explained what gaskets i will need for the d16...everything that comes off of the ehad basicly...even tho i dont need any of the uper end gaskets for the d15 do u think getting the head gasket kit for that motor for all of the other gaskets i need is worth it..or would it be cheaper to peiice all of the gaskets together...and do u know if the valve seals or aanything like that comes with the head gasket kit will fit the vtec head or will i need to get those for the 92-95 civic too?..thanks for ur help
1) You need to get the head surfaced at a machine shop.
You should be able to find the standard head thickness somewhere. Also, when heads are machined, they are left with telltale circular patterns on the surface. Depending on how clean your engine is, you may not be able to see these. Also, even if you can find them, you will have no way of knowing whether the head was simply routinely machined or whether it was shaved at all. You could probably tell pretty easily depending on who owned the car before you.
hey do u guys think i should save the extra money needed to put different pistons and rods in wen i do it or just put it back together with new gaskets and stuff then save for the pistons and rods...then i will have to take it apart again to have the bore over and put the new stuff....my friend got hooked up the aries (i think thats the name) pistons and he had his block bored .40 over....the only thing is i dont know how much more its gunna cost me...what are some good pistons and rods that will be good for when i turbo but not too expensive?...the not to expensice kinda has to include the bore over too..thanks for the help guys
